Greetings all!
I have a '02 wrangler sport with factory fog lights that have never worked since I purchased it some 2 years ago. when i investigated, I found the fuse to be missing so plugged one of the correct value in, and to my pleasant surprise, they came on!
problem was, I couldn't shut them off!
After a bit of research I found out that the multi switch on the steering column that controls them has a weak spot and is a common failure point for the fogs and the best cure is to simply replace it.
But, I'm a cheap skate and also like to keep things simple, so don't want to replace a perfectly fine turn signal switch just for something as mundane as fog lights which is where my question comes in.
I have an empty slot on the dash next to my rear window wiper and defogger switches and would prefer to wire in a "factory like" fog light switch.
i'm pretty good with wiring but can't find a complete enough wiring diagram for either the multi switch or the attached harness to bypass the defective switch with my new one.
I know this isn't really "keeping it simple", but the end result will be for me!
Has anyone had any experience with this? And if so, which wires coming from the multi switch would be the appropriate ones to redirect to my new switch?
Thanks in advance!
Thanks in advance!
