Ok, I've done the searches and tried the tab fix of insulation on cyl 3, changed plugs etc. My issue is the dreaded cylender 3 misfire on a 2004 tj 4.0 with coil rail. It's always cyl 3 and only happens on a warm engine while coasting down hill and no skinny pedal input. It goes into a blinking hard mode and if not corrected into the vehicle limp mode. I dont detect any harsh idle, etc. It dose not give the classic turn off warm then hard restart before cooling down, it only happens when coasting down the hill. I've seen this mentioned but never saw a fix. If it goes into limp mode, I shut down, clear the code and restart with no issues.
Thank you
2004 rubicon, automatic
Thank you
