Alright I know this isn't how many would attack this issue but I moved the axle forward 1/2" and it all fits GREAT. With the flare on it barely rubs and I am getting full stuff on the airbag. I was either hitting the internal bump stop or the mounts inside the airbag. I was lifting the frame and had to lower the axle just a bit.
The airbag is compressed to 6" and I'm not getting any more than that. I think it looks great and works for me.
The lower arm is almost hitting the frame at this point. Didn't you have this happening on yours
@jjvw?
The tire clears the corner at full stuff.
It is just rubbing on the flare here.
Not centered in the wheelwell but who cares?
It could go up a little more here but I'd cut the corner some.
Now time for lunch then switch sides and check clearance on the drivers side.
