My jeep seems to be having an odd problem with warm starts. Starts fine cold but if you drive somewhere and leave it sitting for longer than about two minutes ( ie to pump gas or grab groceries ) it balks when you try to start it back up. While driving the temperature gauge stays well below the 210 degrees midpoint; but if you park and then try to restart the temp gauge will rise to 210 and the engine will splutter until you start moving again. The only way to keep from stalling until you are moving is to rev the engine/ keep your foot on the pedal.
