Isn't it obvious? They placed the air intake as high as they possibly could to avoid sucking in water in deeper water crossings. Same reason they placed the diff and TC breathers (almost) as high as possible.
With the factory setup, you can cross water up to about the top of the grill without issue. I've done so and won't be changing my intake setup.
Yeah, that was a side project I did when I was doing the cowl mold for the CJ Grille Kit. I made the Cool Cowl mold and made a few prototype parts for testing but never did anything further with it.@jscherb cool cowl is the solution!
If you want to believe your TJ's 4.0L engine will benefit from a CAI, go right ahead and run one. This subject has been raised countless (!!!!) times over the past 20+ years and few think it does any good whatsoever.
Not to mention Jeeps are not high-rpms racing machines and very few are interested in such minor gains some think a CAI will get them. My current TJ bought used came with a CAI and it wasn't more than a few weeks before I got rid of it and installed a used factory intake system I obtained from mrblaine. Zero before/after difference discernable... not that I race my TJ at the quarter-mile dragstrip.
If you want to worry about that horn sucking in the air from under the hood, that is your decision. You won't find many here who would worry about anything so insignificant. We're driving JEEPS, not performance race cars whose owners are often obsessed with such things.I am absolutely NOT talking about any of those so-called aftermarket "cold air intake kits" that replace your stock intake assembly and are nothing of the sort.
I am NOT talking about *any* system that uses any kind of oil-filled air filter.
I am asking about why the bottom of the stock air cleaner box has a horn attached to it that points UP and draws in hot, underhood air rather than a different attachment to the same STOCK air cleaner box that connects to the front of the grille that brings in cooler outside air.
From Jeep engineering its narrowed neck after the trumpet opening helps to both speed the flow of air into the intake for more complete combustion and to help make the intake quieter.As a side question: Anyone know why the "horn" is shaped like it is? Its kinda different!
Actually, they take hot air off the manifold full time in arctic conditions to keep the carb from icing up.Those old carb Jeeps take hot air from the manifold when the engine is cold,
That sounds right to me - I figured it was some kind of mini velocity stack - but I didn't know about quieter. Thanx!From Jeep engineering its narrowed neck after the trumpet opening helps to both speed the flow of air into the intake for more complete combustion and to help make the intake quieter.
DittoIs it possible to get one of these still? Or did they never make it to production
Like I said, after making a few prototypes for testing, I never did anything further with it. But recently I lent the molds to someone who is having a fiberglass shop make a few, if that goes well maybe more will be made.Is it possible to get one of these still? Or did they never make it to production
