Rock Slider Style
jazz-n-tj
Hemet
I am looking at getting Rock Sliders soon. I'm pushing my TJ more and more and I am getting too close for comfort going over rocks without them. I have been looking up multiple brands and I see two styles for under-tub protection. The most common style (and usually much cheaper) has about 6 inches of protection for the first 1/3 of the slider. The more expensive brands often times has that protection the whole length of the slider. Below are two pictures of the different styles. Is it worth the extra couple hundred dollars to get the longer protection? I would assume so, but why would so many brands not do the protection the whole way if it was helpful? Lastly, please let me know which brands you are running and your experience (good or bad) with them. Thank you.
Ex. 1 Shrock Works Full length under side protection
Ex. 2 Poison Spyder-Protection only on front 1/3 of under side
Both of those are actually integrated rocker guards and rock sliders.
The Rock slider part is the tubes that stick out from the side and, hopefully, intercept 80% of the rocks you encounter and allow you to slide or pivot over/around them without actually getting very close to your Jeep's body panels.
The rocker guard part is the sheet metal bit and is what you are referring to as far as apparent coverage. This part strengthens and protects your rocker panels (basically, the body panel below the doors) from being crunched if you run them against a rock/curb/shopping cart/annoying neighbor/etc. However; what appears to be added protection in the first example is actually a bit misleading as the part that they are protecting is actually a vertical seam only about 1/4" wide and is, in fact, well covered by both options. The first option might offer a slight bit more protection just from shear mass but, nit really that much. Go crawl under your TJ and look at that area under your doors to see what I mean.
Also, do the first units tie to the frame at all? It kind of looks like the pieces partially off-camera to the left are intended to do so. Tying to the frame is a definite plus as it adds considerable strength to the slider where the second option relies completely on the strength of the panel to which it bolts.
One other thing you are paying for in the first pic is the (I assume) powder coat finish which the Poison Spider option shown obviously lacks. As a rule, I would not pay a great deal for powder coating for such items as a good paint job, followed by after-ride checks for scratches that should be touched up will, in my experience, hold up just as well.
Sorry about using incorrect terminology. I have looked under my TJ multiple times at how these would differ. The wide under protection protects the tub where the body mounts are. The first example protects the tub all the way down the tub whereas example 2 only protects the portion of the tub in the front. Both examples do protect the seam that you are talking about. What I am wondering is when going over rocks is that extra protection needed? I haven't slide over rocks to know what is necessary.
The poison spyder only protects 6" wide until the first body mount (which is the most common type or Rock Guard) the Shrock Work protects to the rear wheel well. See in picture below.
Now I am not sayin I want the Shrock Works. I was only using it as an example. In fact I don't like that the Shrock Works doesn't protect the first 4-6 inches of under the tub. You can see in this picture that it's under tub protection starts after the first body mount, which seems bad considering most of the rock hits will be right after a front tire comes off of a rock.
No problem on the termanology, I wasn't giving you grief, just pointing out a distinction that was important to the discussion.
My TJ has the OE Rubicon rocker guards and independant rock sliders that are welded directly to the frame so, it would be a bit of a rarity for a rock to even get to the rocker guards. I'll go out and look, but my recollection is there is not much in the area to protect...it's a kind of a sunken (OK, raised) area that would be very unlikely to be struck by anything that did not already come in contact with the rocker guard to get there.
OK, looking at that area...UGH! I just realize I must have laid down on a stink bug...God I hate those things!
Anyway, what I see is mostly raised up from the bottom of the panel where the rocker guard would mount and, moving in toward the center of the vehicle, it is not until you get to the body "rigidity box" (just made that up) that anything hangs down that low again.
From your latest pic, it looks like the 6" plate would go to that point and cover even some of the "box" so it might help in those rare cases where a rock protrudes up between the frame and the rocker guard/rock slider without making contact with rocker guard/rock slider first. What that is worth? Hard for me to say. Perhaps others with experiences with either of this type of guard setup can shed more light.
Ah that stinks (pun intended-had to get my dad joke in for the day) laying on a a stink bug. Thank you for checking. I have no side in which is better because I truly don't know. That is why I am asking this forum for everyone's advice to get an idea of which style rock guard I should get.
Here is a photo posted by @Plumber1 in another slider thread showing Poison Spyder sliders at work. I do not believe that he has any concerns about the workmanship or efficacy of his sliders or the protection they provide but I'm sure he can speak for himself.
I have Shrockworks sliders on my LJ, installed by the previous owner whose wife told me that the LJ became "hers" the day her husband installed those steps. Shrockworks builds quality stuff (I have another Shrockworks product on my Xterra), but as with all of the other sliders on the market that try to be both rock sliders and steps, there are design compromises.
Another approach to rock sliders are the Savvy sliders designed by forum member Blaine Johnson. They are very popular on this forum for good reason. It is a well thought out design for true rock sliders.
Depending upon your particular needs, I don't think you would be unhappy with any of these three options. However, if you choose to go in a different direction just stay away from the cheap Chinese junk.
I ran the JCR classic sliders for the last year, but recently took them off for a couple reasons: 1. I never liked having to modify my Savvy body lift pucks to fit them and 2. I noticed some warping of the side of my tub, which is likely due to the you fasteners that hold the slider on and their locations. They did okay at protecting the bottom edge of the tub, but I don't like what they did to the side of my tub.
I have since taken them off and bought Savvys. While I'm prepping the savvy's for Powder Coating an install, I put the stock Rubi guards on.
Edit: my JCR classics are essentially identical to the Poison Spiders.
@mrblaine if you are referring to me as not paying attention, please help inform me. What I’m trying to figure out is if generic rock guard like the poison spyders are sufficient to handle the rocks of Southern California. Is it worth the time extra money to get the full length under body protection. I believe the savvy is full length and from what I understand you helped design them. I want to get what will be best for me in Southern California. But like a $600 aluminum radiator doesn’t out perform The stock $200 Mopar one, price doesn’t always mean better.
He's probably referring to us who just started offering advice without really reading your post and listening to what you are asking. That is why i added another post to tell you about my experience with my JCRs which are like the PS.
@jazz-n-tj
My guess is that you will learn that the Savvy sliders were designed with the toughest trails in SoCal specifically in mind.
Are the Poison Spyder sliders good enough? Maybe. If you can do Dishpan Springs, Gold Mountain and John Bull in the San Bernardino mountains and your sliders stand up to the abuse, and those are the toughest trails you ever intend to encounter, then they may be good enough. Similarly, if you can regularly run Fordyce Creek and not do damage to your sliders or your rig they are probably good enough. Until they aren't. After all, shit happens.
In any event, I doubt that you can ask any designer of a better mousetrap if the prior mousetrap design is good enough and get a enthusiastically positive response.
I should probably add that Poison Spyder has not been an independent company since its founder sold his interest to Transamerican Auto Parts in early 2016 (think 4WheelParts, Pro Comp, Rubicon Express, Shittybilt, etc.). If you value doing business with entrepreneurs who are jeeping enthusiasts, that ship has sailed with Poison Spyder. You will be doing business with Polaris Industries, the conglomerate that owns Transamerican. When you buy from Savvy or from Black Magic Brakes (Blaine Johnson) you are supporting a local economy. Same with Shrockworks from Texas.
@taylormade73
Close, but I think Blaine was actually referring to prior spirited discussions in other threads regarding a particular brand of slider that was mentioned in one of the early posts..
Reactions: taylormade73
@Mr Bill Okay got it. The two examples I used were not two brands choosing, they were just two that had the different style of rock guards and were solely for comparative purposes.
And as for goals, I would like to do Gold Mountain and John Bull but I am too hesitant right now without rock guards. I don't know if I'll get super rock crawling like some of the stuff in Johnson Valley. I'm on a 4" lift and 33" and I figure if I want to get real serious I'll need to go to 35"s and that then opens a whole new can of worms.
If I were in your position I would purchase the sliders with a good reputation that appeal to you most and not worry so much about whether they are the absolute best, especially if not having them on your jeep is keeping you from jeeping. Just try to avoid sliders that have a reputation as damage multipliers.
If you go to 35's and start building for Johnson Valley you will probably replace most of the stuff you've purchased anyway - including your sliders - and there will always be a market for good used but not abused jeep parts.
I can think of a set he'll not need to replace no matter where he choses to go.
