This is a feature I seldom use on my LJ OEM/Mopar Sunrider top and not even sure if I am folding it back correctly. But can someone confirm or chime in on how is the fabric that is flipped back supposed to lay/sit above ones head?
How I understood the sunrider feature works is, you release the headers, release the two drip rails above the door. Slide the locking barrel or however you want it to call it to allow the joint on the soft top frame to pivot which lets you fold the front portion back.
Now with the front portion folded back, you take the door rails and create a V kind of like when folder the top fully back to let the material fold itself in. Tuck the V into the center which folds the fabric down. I find the sunrider top there is still a fair bit of fabric left over my head when its folded back. Is this normal? As I am driving depending on the wind it can also get the fabric and even pull it into the Jeep and at that point it actually sits on my head.
The LJ has the two little clips that are near the B pillar on the door surrounds, pull tabs if you will. Are these supposed to be released when using the sun rider option? Perhaps I am folding the drip rails the wrong way and they are supposed to paint back towards the Jeep and not center?
