How do you like that air intake setup? It would be nice to gain the room the factory box takes up.
Love it!How do you like that air intake setup? It would be nice to gain the room the factory box takes up.
Installed a Joying 8.8” single-DIN Android floating screen head unit. The widescreen aspect ratio fits perfectly between the vents and HVAC controls, though I need to adjust the screen up a little. It has wired and wireless CarPlay, and looks and sounds great. And because it’s single DIN, I was able to keep my silver bezel.
View attachment 181976View attachment 181978
I really like how the large screen fits in that area.So I added wireless steering wheel controls from Amazon today since this uses a touch screen slider for volume control. That’s probably the only knock I have on the unit... It's almost unusable while driving... But this fixed it. I just used the volume one and mounted it on the back side of the steering wheel.
I also adjusted the screen up one setting and it looks better. Even though it’s above center, now when I’m looking down at it, it isn’t blocking the view of the HVAC controls anymore. I had to remove the trim that hides the mounting brackets and ribbon cable, but it's tight enough to the dash/single-DIN adapter that you can't really see them anyway, so I'm fine with it.
Now I just need it to connect to my OBDII scanner to use torque and I’ll be all set.
busy day and welcome!! where in Chesapeake? I lived in Grassfield up until 2 years agoI just got my tj a week ago. A few days ago I looked and saw that the radiator had a JB weld fix on the top of it and the hoses were bulging out. So today, I replaced the radiator, water pump, thermostat and housing, and radiator hoses. Also gave everything a little flush while I was at it.
I live in Grassfield! We just moved here from Deep Creek in January.busy day and welcome!! where in Chesapeake? I lived in Grassfield up until 2 years ago
That'll buff out!This is for the amusement of our non-rustbelt area friends. As I said above I replaced my front brakes. Here is what a caliper looks like when its been salted and sat
View attachment 182528View attachment 182528View attachment 182530
