I have a 97 TJ 4.0 standard with 73,000 miles on it. When I am driving it wants to stall then cuts back on. The rpm gauge & speedometer will drop to 0 until it comes back. When it stalls, sometimes the rear tires will lock up until I kick it in neutral. When it cuts off, sometimes it will take a few minutes before it will start back up and it is acting like it’s flooded. The fuel pump kicks on just fine. I was told to clean the throttle body, which I have done.
It was throwing engine codes for cylinder 4 & 6 misfire and throttle position sensor. I have since reset the CEL and it is still doing it. This time when it did it, it did not throw a code.
So far I have replaced the crank shaft position sensor, throttle position sensor, plugs and distributor.
The transmission is needing to be rebuilt. I was told it was the synchros. 3rd & 4th gear grinds when going in gear.
Any ideas?
Any ideas?
