Hey guys,
I've got an '06 TJ with 4.0, and 6 speed.
It's done this odd thing where it cuts out under acceleration since I've had it. It would flash the CEL but never store a code. If I backed out of the throttle, it would continue to run, but if I kept on it, it would die. Over the two years I've had the jeep, I've replaced many parts trying to track down the culprit. Here's the List:
Crown OPDA
Cheap Camshaft Position Sensor
Mopar Camshaft Position Sensor
Cheap Crankshaft Position Sensor
Mopar Crankshaft Position Sensor
Cheap Coil Rail
Mopar Coil Rail
Replaced the plug that goes to the coil
Sparkplugs
ASD Relay
IAC
Battery Terminals
Through this time, the problem has gotten worse, but not after replacing any one part.
The jeep will start if cold soaked, and run great for 15-20 Mins, and then die. No stutter, no prior RPM drop, just out of the blue, Stall. Still has no codes, or freeze frame data. When trying to restart engine, it will crank as normal, and fire what sounds like maybe one CYL randomly, but not start.
Any help is greatly appreciated! I'm about at my wits end.
Crown OPDA
Cheap Coil Rail
Mopar Coil Rail
Sparkplugs
ASD Relay
IAC
Battery Terminals
