Do I ditch the DPA or keep it. Clayton 4" LA, Clayton track bar their drop bracket and Currie steering. Sorry the pics aren't that great.
Tell that to Rubicon Express track bar that decided to part ways with my factory bracket! But... I am thinking I will cut the bracket off and go back to the factory bracket and possibly a different track bar.The driver's side mount of the track bar doesn't need to be double-shear, the factory design single-shear is plenty safe for the highway. I'd go back to the factory single-shear track bar mount and non-dropped Pitman arm.
You're blaming the wrong end of the equation. Blame RE, not the single-shear design. I got rid of my POS RE track bar setup. The driver's side mount of the track bar doesn't need to be double-shear, the factory design single-shear is plenty safe for the highway. I'd go back to the factory single-shear track bar mount and non-dropped Pitman arm. Single-shear is good enough for the more astute companies like Currie and Savvy.Tell that to Rubicon Express track bar that decided to part ways with my factory bracket! But... I am thinking I will cut the bracket off and go back to the factory bracket and possibly a different track bar.
I used to think the same thing until I noticed my axle was impacting the dropped RE track bar mounting bracket when the driver's side tire would try to stuff up into the fender well.Your rig should ride just fine with both dropped. As long as they are both stock style or both dropped you will be fine.
As already said above, you're blaming the wrong side of the equation, blame RE not the single shear track bar mount design that works well enough that Currie and Savvy use it as-is. That design holds up to lots of abuse even on King of the Hammers race vehicles.I understand, but when the POS track bar separates at 70mph and you have a shit your pants moment, you consider a double shear mount!!!
Not sure why you cut out the rest of my post that addresses this.I used to think the same thing until I noticed my axle was impacting the dropped RE track bar mounting bracket when the driver's side tire would try to stuff up into the fender well.
It definitely wasn't intentional, I was editing my post from my cellphone and apparently fat-fingered which one I was editing. Please restate what you said addressed my concernsNot sure why you cut out the rest of my post that addresses this.
