You will need an LED flasher relay like this:
https://www.amazon.com/dp/B000JZ79NC/?tag=wranglerorg-20
That will allow you to install the bulb without hyper flash. It also allows you to convert the remaining lights to LED as well, so you can replace the front and rear lights with LED without any issues. It will work with LED, incandescent, or a mixture of bulbs.
