Very much overkill. But, a simple solution is to carry a spare set of front shafts put together with u-joints. If you get to the point where you've had to swap them in due to a break, then solve the problem. Right now, you don't have the problem, don't solve it.Do I need 4340 chromoly shafts for a Dana 44 that is locked running 33's? Or is that overkill?
I would rather he not wind up like the buttheads who recommended everyone run RCV shafts right after they first came out. I asked all of them I ran across how many shafts they broke before the swap. Across the board it was none. What other alloy shafts have you run? None, just stock. Oh, so you are telling everyone to run some newfangled unproven shaft and you've never even broke a stocker? Yep, that's right because RCV. Yeah, go away.I ran stock 44 axles for a long time with no issues, and so have many others. I only switched when I found some slightly twisted splines. Unless you have a heavy foot, or get yourself in bad situations routinely, I see them as more of a nice to have than must have.
Edit: Nice to have on 33" tires
I've seen lots of broken stuff. Almost none of it on 33's.I personally have seen broken Dana 30 and 35 axles, but never a 44. I have seen a couple sets of twisted 44 splines though. Not horrible mind you, but definitely tweaked!
The short answer... no.Do I need 4340 chromoly shafts for a Dana 44 that is locked running 33's?
Good advice, I saw a set of stock Dana 44 shafts off of a TJ for $40. Thought I might swipe those up for trail insurance.Very much overkill. But, a simple solution is to carry a spare set of front shafts put together with u-joints. If you get to the point where you've had to swap them in due to a break, then solve the problem. Right now, you don't have the problem, don't solve it.
I'm very easy on the skinny pedal. As you know, off-road driving takes finesse, you're just looking for traction, a small bump here and there can be helpful, but rarely does a lot of gas solve a lot of problems, it usually is the cause of them.I ran stock 44 axles for a long time with no issues, and so have many others. I only switched when I found some slightly twisted splines. Unless you have a heavy foot, or get yourself in bad situations routinely, I see them as more of a nice to have than must have.
^^^^^^^This ^^^^^^^I'm very easy on the skinny pedal. As you know, off-road driving takes finesse, you're just looking for traction, a small bump here and there can be helpful, but rarely does a lot of gas solve a lot of problems, it usually is the cause of them.
Too many off readers just hammer down with no sense of feel.
It’s a way o life to some and they need to show off their hemi even if they aren’t very lite bright.I see this frequently, which is usually followed by wheel hop and the crack of an unhappy u joint!
We talking front and/or rear or does it matter?
Identical here.The only axle shaft I ever broke was a Dana 44 rear Ten Factory while running 35’s. Tire was slightly wedged and as soon as I let the clutch out it popped, less than 2,000 rpm and very gentle with the clutch pedal. Shitty part was it also destroyed the Rubicon locker.
