So a little update. I have been chasing issues ranging from my dash gauges shutting off, jeep intermittently stalling, multi cyl misfire, all 4 o2 sensors heater fail high and low voltage, chugging, crank sensor. You get the point.
I cleaned all connections and traced all wiring. Found nothing. It was suggested to me to contact Mark at wranglerfix.com. I am so glad I made that call! Mark was the one that answered and he told me all the symptoms of a failed/failing PCM before I told him the issues I was having. After talking with him for awhile I chose to order one from him. He told me it would be a couple of weeks to build one. And after a shipping issue he went and had one overnighted to me. Not only is he a genious to cure the tj pcm issues but his customer service is top notch!
I have had the new PCM from @Wranglerfix in the jeep for 400 trouble free miles now. Today I decided to put the old pcm in to test it since the weather has been cool and after about 20min of driving the gremlins started back up. I pulled I to a gas station and changed out the pcm and 5 min later co tinued on with no problems.
So if you are having the issues I listed or the cel codes I'll post give mark a call!
