What is the typical size for front spacers used to level these things out? My front sits a little lower due to the factory rake. I'd like to make it level. My thought was either a 1/2" spacer or 3/4" spacer.
That Jeep in the background looks great!
I was thinking the same thingThat Jeep in the background looks great!
If I didn't already own a close clone to it then I'd highly consider it.You could always use two
How about you put those 35's on the Silver jeep. I heard you can run 35's with no lift
For my Jeep, Dave took out the factory 3/4" spacer and added a 1-3/4" spacer to level it out. We were able to get a bit of additional shock travel from this given I am running 11" fox shocks with the long free length Savvy 3" springs (note that front did not get 3" lift though my jeep is quite light).
What exactly IS your plan? Level the Jeep, add a BL, then TT, run 32's, then done for now?
What exactly IS your plan? Level the Jeep, add a BL, then TT, run 32's, then done?
Are you still putting a Savvy bumper up front? I remember you putting one on awhile back.
