You're tough to keep up with, you know that right?
1. You rail for pages about "spacers" being un-safe and your reasoning....is people don't keep up with maintenance.
2. You rail about inspecting, and that OEM is "right" for a reason.
THEN
You state 35's without the right brakes to actually stop the massively heavier tires with exponentially higher centrifugal force being run on a rig that was built for 30" tires ......ummmmmm is right, which is it???? You're against completely safe spacers (no one suggested not maintaining them) but you're for 35's on stock brakes?
You also completely discount 35's on axles' "by osmosis" by the way, not sure you know the definition of that word. You keep stating "Mild Wheeling".
My 16 year old son pulled our 2005 Jeep TJ....running 33" tires (not even 35's) and pulled out of a parking lot at the park.....on asphalt.....and the rear driver's side OEM/Stock axle snapped. In the TJ setup, and I'm sure you know this, if it snapped when he made a turn on a road doing 35 mph......Yeah, that's safe? That's okay? Breaking stock axles on pavement let alone mild wheeling, is very real.
When someone says they want to do something, that even done correctly, is not good, I appreciate that guys like
@mrblaine or
@Jerry Bransford are pointing out how stupid it is, or that I'm setting my 16 year old up to lose a freaking wheel and have it slide out, I wish I would have known when I bought him the TJ.
"CAN" you....as you've referenced the OP....yes you can mount 35's on a TJ with 2" lift and cut the fenders....sure, you can bolt them on....but it's stupid. Sucks that the parts are expensive up there, but it's still dumb. You can get cheap parts and do it cheaper, and get what you pay for, and that's 100% a doable and nothing to be embarrassed about, sometimes you get what you can.
