My question on this is somewhat different in case of a breakdown and you used a bolt or stub shaft, what do you do with the inner? Can't remove it as all the oil would exit, correct? Can't leave it flopping around inside the tube, as that would cause damage to many things, wouldn't it?
So outside of having a spare set of assemblies for the front, I'm also trying to figure out what 'could' get you out.
