So I finished up my PRP seat and bench install. I ended up purchasing the Enduro Elite seats and I want with a 40" Enduro bench. I was a little nervous going for a 40" since PRP only lists 39" as the supported TJ width. Fortunately it worked out with about 1/2 to spare.
I ripped out my old seats and cleaned and painted the bases. The flip forward still works if I reach underneath and rotate the bar. I may look at welding in a tab or handle in the future.
The seatbelt needs to be extended and bolted to the base. I used some 1/8" flat bar that I bent with a vise and BFH. I kept it long enough to get two grade 8 bolts on it. The off centre hole is actually repurposing an existing hole that needed to be enlarged.
It was a really tight fit and the seatbelts slide against the console. I may look to shorten the angle bracket or even replace the seatbelt receiver with something different. They fully recline and still flip forward.
For the rear bench I wanted to keep the angle, height and positioning as close to stock as possible. I figure they put these TJs through safety testing so might as well try to keep it close.
The factory bench is at a 17 degree angle, 11.5" high from the front, and about 10.5" back from the console.
To get the same measurements for the Enduro bench I had to raise the front 3.5" and the back by 2.5".
I ended up using some 2"x1" 1/8 channel that I bolted on its side. I then welded in some 3/16" flat bar as the mounting tabs.
I still need to pull it all apart to have the bench mount powder coated or painted but I am very happy with the end result!
