steering gets tricky. deviate from the OE TRE's and it can get into the rims. not sure about the synergy TR but if it doesn't curl around like OE at the TRE's it's likely not gonna fit an OE rim, but i'm not positive hereWhat steering are you guys using? I'm thinking of ordering Synergy and modifying as needed. Custom full-length track bar. Never have messed with JK axles except lockers and regear.
i run 1 ton offset TRE's and a 1.5 aluminum TR bar. the drag is 1.5 DOM mounted OTK.
i changed my pitman arm, the TJ arm leaves room at the knuckle for more turn travel so i tried to get some of it.
i moved the TB connection out to the C, this presents it's own special problems as well (there is no out of the box TB made for this).
when everything compresses the TB comes up parallel with my DL and has about 1/8" clearance room. then the diff cover comes up tight to the TB it with 1/8" room. it's as far forward as my linkage set will allow.
if you start dickin with OTK, depending on the amount of up travel you can generate you could have to notch the pass side frame some to get full movement.
