AidenC
I have my rear cat and muffler replaced with a straight pipe. It's not stupidly loud compared to running open headers and it sounds great starting up in the morning.
thank youIt’s won’t hurt it at all. You’re just going to have a CEL all the time. I’m thinking the top 2 O2 sensors control the mix before the cats.
I am in Tn no test hereDepending on how plugged they are you might just drop them and clean them out. You won't pass an emissions test but you will get back all the power. I did this 3 years ago, No issues but we don't have emissions testing either.
not sure hoping for the secondary that is on the skid plate so I can cut the pipe there and check it clean it out if needed and reattach with a coupler without having to pull the primary cats. I know I am going to have to pull them eventually to replace they are almost 20 no they are 20 years old. I just don't have the excess cash at this point.what cat do you think it is causing trouble?
what would you do with the existing ones then? I don't think it would throw any code if you moved the sensor bungs to fit a spark plug non fouler on it. I wish there was a way to disable the afterflow O2 sensors.bringing back this thread. cant you use o2 sensor bungs, weld them on to the tube and out the sensors back on?
Early TJs like your 97 did have a problem with their cats coming apart inside and rattling. My 97 did the same thing but it was still under warranty so the dealer replaced it with the updated catalytic converter. You can take a mallet and bang on it a bit to see if you hear it rattling inside to confirm if it's the source of the rattling.So I've been hearing a rattle when I'm idling and when I'm at about 1800 rpm. I think it's the cat but im not 100% I have stalled a few times and it does seem a little bit down on power. And it just put up a p0441 code
Thank you very much I didn't know that abt the early TJs ill look into it tonightEarly TJs like your 97 did have a problem with their cats coming apart inside and rattling. My 97 did the same thing but it was still under warranty so the dealer replaced it with the updated catalytic converter. You can take a mallet and bang on it a bit to see if you hear it rattling inside to confirm if it's the source of the rattling.
The P0441 code indicates a leak in the evaporative system. That can also be caused by starting or running the engine while the gas cap is off.
Finally, that P0441 code says you used an external code reader. Your 97 can produce its own DTCs (diagnostic trouble codes) by turning the ignition switch on-off-on three times within five seconds and then leaving it in the On position. Give the diagnostic route time to work, 4-5 seconds is enough, and any stored codes will start displaying in your odometer. If you did it right you will at least see a '55' code which simply indicates there are no more DTC codes to follow.
Since the '97 produces two-digit codes instead of the P0123 type codes of newere TJs, here's how to decode them... https://www.allpar.com/threads/the-1980s-1990s-chrysler-computer-codes.229009/#post-1085223107
It works... very nicely at that.please do try it and let us know!
That's the magic number. The magic number for my '87 XJ was 20-21mpg hiway burning straight 86 regular; ethanol busts it to 18-19 mpg. Once, I got 26mpg blowing through Kansas with a tail wind. They sold no ethanol there.went back down to 15 mpg no matter how easy or hard I would drive it.
How would I go about removing the post O2 sensors on my 01'?5 years later
I've removed mine a long time ago. My post was from 2016![]()
