Hi Folks, At a dead end...
I remove a 4" lift on my Tj, replaced it with a RC 2" lift. replaced the drop pitman arm with a stock one.SLOW SPEED VIBRATION...
I have taken out the front drive shaft, just to confirm it wasn't a u-joint problem.. it wasn't. iI have dropped the crossmember from stock location to 1/2" drop, 3/4" drop, 1" drop and 1 1/2 " drop ,, same vibration... the rear shaft feels tight ,,,no SLOP IN IT....
Put an angle finder on the differential it read 11 degrees, the drive shaft reads the same 11 degrees,,,,
SAME VIBRATION.. It is in the drivetrain , somewhere...
Thanks
Thanks
