2004 Rubicon 42RLE stuck in second gear
inlovewithrubi
Wolcott, Connecticut
I am at my wits end !! The details 04 tj rubicon 4.0 42rle. Got into my jeep one morning and it was stuck in second gear. Replaced solinoid pack, filter , new fluid. Still stuck in second gear. Brand new aftermarket transmission, and new TCU. Still stuck in second gear. All connections correct no visible damage to wiring. I am lost, and don't know where to turn next.
Last thing found before I had to go to sleep for work. Electronics connection on drivers side was not secure. Also found that O/D override switch was not working.
Reactions: Wranglerfix
May be unrelated and too simple, but have you checked the internal shaft on the shifter? Mine snapped once when trying to reverse into a spot. These have been known to break. Just pull the handle off and see if the plastic is free floating (it shouldn't be).
Correct, I am aware of this happening, but my jeep is stuck in LIMP mode/ second gear.
The shifter in the cab will cycle through all the gears, but trans will not go into first.
I do currently have my locker pumps out while I clean them up and make provisions for a new location.
i have the exact same problem its been like 8 month since it begins and i really dunno what to do i did exactly the same as you did but its useless so if anyone knows how to solve this please tell me
What diagnostic trouble code is it generating?
i'm really tired of trying solving this problem i did everything i know like gear cooler changing vlave body and Replaced solinoid, filter , new fluid nothing worked its been like 8 mouth or more i did read about this problem and now i know that its called limp mode or something...
btw the car is shifting good when its cold but when its a lil worm this limp mode thing happen so like when i turn the car on its shifting for like 20-30 min then this happen.
if anyone knows anything please help !
@albshri I am mark with Wranglerfix. The codes you are getting for your 06 are pcm failure without question!
Can you take a picture of the authorized software update number on the pcm please?
Reactions: Jerry Bransford
We use a different pcm that is modified to work in the 05-06 TJ’s. The oem unit is not repairable. Send me the photo tomorrow and I will verify the software needed for yours.
Thanks,
Mark
