Auto trans. Stuck in reverse. Jeep won't start because it's in reverse. Solution?
Took the shifter cover off and found a bolt that had left my cup holder and worked it's way under the shifter. I think it jammed when shifting. Removed the bolt and shifter can now move, but it's stuck in reverse no matter which gear I select.
