Here's one for your TJ history buffs. Last year, I bought a '06 Khaki TJ and it was registered in the UK as a Wrangler Renegade. It's not a trim I've heard of and I've been curious to see what the original spec would have been so I can try and restore it back. However, I did some digging and ran a VIN check through Jeep and they have the build sheet as an '05 Wrangler Sport with all the Sport badging. Found the original dealer but they've closed so I am back at square one. So my question is, why is it registered as a Renegade and what would that spec have looked like? I've pasted the Jeep build sheet and a photo of my Jeep below:
(Side note, it says below the original wheels were the Ecco wheels but then just under it also says "all aluminium wheels". Weren't the Eccos alloy wheels?)
Vehicle Description 2005 JEEP WRANGLER SPORT (RHD) 4X4 SPORT UTILITY 2-DR
STANDARD EQUIPMENT
STANDARD EQUIPMENT
- * Export Equipment Group
- * Monotone Paint
- * Smoker's Group
- * 117 Amp Alternator
- * 600 Amp Maintenance Free Battery
- * High Back Bucket Seats
- * Easy Access Driver Tip & Slide Seats
- * Reclining Front Seats
- * Rear Folding Seat
- * Traveling Inboard Seat Belt Buckle
- * Next Generation Front Air Bags**
- * Front Seat Area Carpet
- * Rear Seat/Wheelhouse/Cargo Carpet
- * Cargo Tie Down Loops
- * Front Floor Mats
- * Sport Bar w/Full Padding
- * Spare Tire Cover
- * Full Length Floor Console
- * Command-Trac Part Time 4WD System
- * Dana 30/186MM Front Axle
- * 3.07 Rear Axle Ratio
- * Heavy Duty Dana 44 Rear Axle
- * Tinted Windshield Glass
- * Rear View Day/Night Mirror
- * Manual Mirrors
- * Sentry Key Theft Deterrent System
- * Heater w/Instrument Pnl Ventilation
- * Instrument Cluster w/Tach
- * Var Intermittent Windshield Wipers
- * Single Low Note Horn
- * 12V Auxiliary Power Outlet
- * Locking Glove Box
- * Lt. Quartz - Badge - Sport, Cowl Sid
- * Lt. Quartz - Badge - Jeep, Lower Cow
- * Lt. Quartz - Badge - Wrangler
- * EXTERIOR COMPONENT COLOR
- * Halogen ECE Headlamps
- * Rear Fog Lamps
- * CHMSL Lamp
- * Black Front Bumper
- * Black Rear Bumper
- * Bumper Extensions
- * Chrome Headlamp Bezels
- * Black Front Frame Overlay
- * Body Color Grille
- * Export Emissions
- * EVAP Control System
- * 19 Gallon Fuel Tank
- * Light Khaki Metallic Clear Coat
- * Fixed Long Mast Antenna
- * AM/FM Compact Disc RDS Radio
- * Power Steering
- * Steering Wheel
- * Normal Duty Suspension
- * Front Stabilizer Bar
- * Rear Stabilizer Bar
- * Tilt Steering Column
- * Full Size Spare Tire
- * Outside Tire Carrier
- * Upgraded OBD-II Connectors
- * Fuel Tank Skid Plate Shield
- * Transfer Case Skid Plate Shield
- * Tow Eye Brackets
- * Locking Lug Nuts
- * Tethered Fuel Filler Cap
- * Locking Fuel Filler Cap
- * Protective Coating and Remover
- * Build To Export Mkt. Specifications
- * GVW Rating - 4450#
- * Export Homologated
- * Zone 06-Export
- * TJ-Vehicle Family
- * Right Hand Drive (RHD)
- * Price Class H
- * No Cargo Box
- * Short Wheel Base (SWB)
- * Vehicle Order Tracking
OPTIONAL EQUIPMENT - * Cloth High-Back Bucket Seats
- * Khaki
- * European Equipment Group
- * United Kingdom Equipment Group
- * Tire and Wheel Group (Ecco)
- * Convenience Group
- * 4.0L ENG(ERH)/6SPD M/T NSG370 (DEH)
- * 4-Wheel Anti-Lock Brakes
- * Easy Access Pass Tip & Slide Seat
- * Removable Ash Tray
- * All Manual Transmissions
- * 6-Speed Manual NSG370 Transmission
- * 4.0L I6 Power Tech Engine
- * Light Tint Front Door Windows
- * Full Metal Doors w/Roll-up Windows
- * 110 MPH Primary Speedometer
- * Cigar Lighter
- * Headlamp Leveling System
- * Courtesy Lamps
- * Underhood Lamp
- * Euro Stage 4 Emission Vehicle
- * Next Generation Engine Controller
- * All Radio Equipped Vehicles
- * 7 Speakers Inc Subwoofer/Tweeters
- * P225/75R15 OWL Wrangler AT Tires
- * Goodyear Brand Tires
- * Dark Khaki Soft Top
- * 15X7.0 "Ecco" Aluminum Wheels
- * Matching Spare Wheel
- * All Aluminum Wheels
- * Unique Export Fuel Tank
- * English/UK Language
- * 5 Additional Gallons of Gas
- * Spring - Left Rear
- * Spring - Left Front
- * Spring - Right Rear
- * Spring - Right Front
- * FAM: TJ TRACKING: 40923J07 MY:2005
- * Customer Preferred Package 2TD
- * Customer Preferred Package 25D
- * Intl. Price Protection B
- * Coso Wt. & D.M.
- * Market Homologation
- * Export Ocean Freight
- * Export Insurance
- * 1NTL 37 DAY SCHEDULE
- * Special Scheduling Condition III
- * Delete Domestic Warranty Manual
- * Export Option Requirements
- * Certificate of Conformance
- * Paint Order Code
- * European E Mark Label
- * Manufacturer Body Plate
- * United Kingdom Country Code
- * Western Europe Region Group
- * EMEA Region (Europe)
