Fender turn signal fasteners
minimull
Arizona
Anyone have a part number or know what the plastic nuts/fasteners that hold the turn signal lens in on the fender?
Mine had nuts that were basically stamped out of sheet metal. You could thread them on and off easily. The star lock ones can be hard to remove without damage.
Good info! My last TJ had starlock washers on it. I am guessing someone must have replaced the factory ones with the wrong part. Thanks for clarifying 👍
Star lock are not removeable without damage to the post or the lock. Single use only.
Awesome! Thank you! So happy to have so much support on my first post, especially on something so small. I’ve been reading on this forum for a few months and look forward to posting more as I work on my TJ and LJ.
Reactions: qslim
Welcome! We have all the knowledge here to make your TJ & LJ pop & spit flames.
I use tight fitting vacuum hose. I have broken a couple on trees or rocks. Now I remove the marker lights before hitting the trail. The vacuum hose makes easy to remove with out tools.
Do you guys know what size the torx (T15) screwz would be using regular Philips self tapping screws? I knocked the jar over and lost all of them in a very dirty repair shop. I know it was a t15 torx that I used to remove them, lol. Thanks!
Edited.
If you are looking for screws for the front marker/turn signal lamps, they are listed in the parts lists as 0.164 inch 18 tpi. Which is a #8 thread.
