They are not star lock washers, they are about a #12 stamped steel nut, similar to these with a 10mm hex.You can get those at ACE Hardware or Home Depot. They are called starlock washers:
https://www.amazon.com/dp/B07MHC5GHS/?tag=wranglerorg-20
Good info! My last TJ had starlock washers on it. I am guessing someone must have replaced the factory ones with the wrong part. Thanks for clarifyingThey are not star lock washers, they are about a #12 stamped steel nut, similar to these with a 10mm hex.
https://www.summitracing.com/parts/...MI15_Po7Tl7gIVRQp9Ch1XUgYZEAQYBCABEgIlS_D_BwE
Star lock are not removeable without damage to the post or the lock. Single use only.Good info! My last TJ had starlock washers on it. I am guessing someone must have replaced the factory ones with the wrong part. Thanks for clarifying![]()
Welcome! We have all the knowledge here to make your TJ & LJ pop & spit flames.Awesome! Thank you! So happy to have so much support on my first post, especially on something so small. I’ve been reading on this forum for a few months and look forward to posting more as I work on my TJ and LJ.
Spot on mrblaine! All buttoned up and looking brand new now, thanks to you.They are not star lock washers, they are about a #12 stamped steel nut, similar to these with a 10mm hex.
Edited.Do you guys know what size the torx (T15) screwz would be using regular Philips self tapping screws? I knocked the jar over and lost all of them in a very dirty repair shop. I know it was a t15 torx that I used to remove them, lol. Thanks!
