I’m just gonna turn this into a journal of sorts for anyone who might take their own adventure into removing a 3 inch body lift. It might save someone some time. So I got all the pucks off. The passenger side was quite difficult to get lined up. PO had done something to cause the tub to lean forward. I figured out if I slap some wood blocks under the rear tires I could get the wheels stopped up enough for the winch to work it’s magic. Got it lined up only to find that the middle frame bolt does not go in. Im guessing the threading was damaged from the leaning so I think I’m gonna have to tap it out but I am hoping once I get the rest on some Jeep angel will bless me. Got the drivers side down like a breeze.
The problem I’m having there is the transfer case linkage. I can for the life of me get the bar into the hole on the t case housing and into the tub bracket. I honestly gave up on it tonight and will try again tomorrow. Now I’m going at the fuel tank now that it has a fresh pump module in it just to get it out of the way. Already relocated the radiator and shroud. All that’s left is the steering but I’m sure some kind of hiccup will appear. If anyone has any tips on the t case shifter linkage that would be rad. I know most will say get the savvy cable but that is for a later date as I’ve already dropped a few hundred in the past couple days on it.
