About step #2. After you remove the oil seal, you then hit the only snap ring and one of the first lock rings.
Mine has a Harmonic Balancer so it was more like step 3 (Remove balancer, remove oil seal, then hit the snap ring (and a lock ring)). Without the Harmonic Balancer, it's more like step 2.
Assuming you don't count dropping the skid and removing the DS as steps.
Edited: 'Couple beverages in' edit - needed to remove yoke ref. Confused the front DS and rear DS.....
