OK, a couple weeks ago I replaced my water pump when it went out, and the clutch too within the same week. I haven't had any problems for two weeks so I don't think any of my current problems are related to a loose wire or anything.
Yesterday while running about 50 mph my jeep just cut out for a split second and quickly picked right back up where it left off. It continued to surge like this once every mile or so. I got home and assumed it was possibly my coil pack going bad, No error codes or anything though. I changed my coil pack out in about 15 minutes to one I already had on the shelf, but It didn't fix my problem. Decided to keep driving it in hopes that it would eventually throw a code. I decided to run some seafoam through it just in case it was some bad fuel, to no avail. Today, it is much worse, jerking every 20 seconds or so. RPMS drop rapidly almost like turning the engine off briefly and right back on within half a second. I am thinking its possibly one of my upstream O2 sensors and have them ordered, but still not sure since I have no error codes. I did hook my scanner up and ran some tests while driving. I don't have a clue as to what I'm looking at on the majority of these tests results. I'm hoping someone can look at this and tell me what might be the problem.
Test drive at 50 mph:
MIL STATUS OFF
ABSLT TPS% 32.6
ENG SPEED (RPM) 1708
CALC LOAD 22.0
MAP (HG) 20.7
COOLANT (F) 190
IAT (F) 117
IGN ADV. 28.0
ST FTRM1 % -5.5 (Short Term Fuel Trim)
ST FTRM2 % -4.7 (Short Term Fuel Trim)
LT FTRM1 % 4.7^ (Long Term Fuel Trim)
LT FTRM2 % 3.1 (Long Term Fuel Trim)
VEH SPEED (MPH) 50
FUEL SYS 1 CLSD (Fuel System 1 Loop)
FUEL SYS 2 CLSE (Fuel System 2 Loop)
02S11 (V) 0.740^ (O2 Voltage Bank/Sen)
ST FTRM11 % -6.3 (Fuel Trim Bank Sensor)
02S12 (V) 0.660 (O2 Voltage Bank/Sensor)
02S21 (V) 0.700 (O2 Voltage Bank/Sensor)
ST FTRM21 % -5.5^ (Fuel Trim Bank/Sensor
02S22 (V) 0.660 (O2 Voltage Bank/Sensor)
OBD2 STAT CA (OBD 2 Status)
Anyone know much about this stuff? I went out a little bit ago and was holding the motor on about 1500 RPM and was watching the "FUEL SYS1" and "FUEL SYS2" reading. I noticed as soon as the motor started missing they both went from showing a numeric, to showing closed. If its not a O2 Sensor, could it be my Crank Position Sensor? I obviously had it off when I changed out my clutch. Thank yall for any help.
MIL STATUS OFF
ABSLT TPS% 32.6
CALC LOAD 22.0
MAP (HG) 20.7
COOLANT (F) 190
IAT (F) 117
IGN ADV. 28.0
VEH SPEED (MPH) 50
