I bought a Zone combo without shocks. JKS adjustable front and rear track bars. Upgraded to the ZJ steering linkage. Bought the recommended RS5000x shocks. With stock control arms, no motor mount lift or transfer case drop, it was un-drivable. The rear driveshaft/u-joint angles were so bad. Had to stack about 1.5" of washers between the transfer skid and frame to get it tolerable. It would shake just a hair upon takeoff from a stop, but smooth out. Decided to not drive it very much until the budget healed. Went with an SYE and Tom woods rear shaft. Then went with adjustable control arms (full set) to dial in the pinion angles. Maybe the 3" Zone springs are more than 3" lift. Maybe I was just unlucky. I'd read about others with various brand 2.5" or 3" lifts and not need the other upgrades. But it was truly undrivable with just the springs installed. Motor mount spacer kit might have fixed it. But I also wanted to have the better stuff in case I, or another owner decides to push it further.
I ended up not putting the body lift on, since the height achieved with the suspension part of the lift satisfied my wants. But if I did put a body lift on, I think I would go with someone else's with metal spacers instead of plastic.
Hindsight: I might go with double adjustable arms vs. one with a bushing on one end and a Johnny joint on the other.
I am very pleased with the road manners of the Zone springs and RS5000X shocks. No real experience yet with it offroad. I've been working on it for 2 years and finally have it ready for some trails, etc.
I did go with the Savvy transfer case linkage upgrade. I should have done it when I was messing around with the transfer case, SYE, etc.
