99 Jeep TJ
The problem began with the Fan Speed Switch dying...I replaced that. Worked fine. Then it died again. So I bought another switch. Plugged it in and nothing happened. I began to read forums and discovered the dreaded damndable TJ Blower problem. Everyone suggests it could be the relay or the blower fan. So I replaced both of those.
So now I have a new relay under the glove box (I cleaned out a forest of dried leaves just behind it). I have a new blower motor. And when I went to turn the fan on and up...nothing. Tried putting in the brand new switch. Nothing. Tried the old switch I never threw out. Nothing. Fuses are all fine. Can't find any melted wires.
Could I have killed the brand new switch that quickly?
What do I do now? What is the next step when you've replaced everything that could be the problem?
