03 sport w/ 4.0
Been having a rough idle at start-up when engines hot, seems to be missing. Usually can give it some gas and things pop back to normal. Lately, giving it some gas doesn't seem to do anything, rough feeling stays, no real change in RPM, still seems to be missing. Turning off and on doesn't change this. Eventually it stops.
Today, sitting at idle for a few minutes after commute home, engine drops to that weird, half idle and seems to be missing. Turn jeep off, start it. Runs fine. Idles for a few minutes and does the same thing. Turn it off again, starts up fine again no problem. No codes present.
I don't think its related to the IAC, its been replaced and also the issue seems to go away when giving it gas. I also had a hanging idle when pushing the clutch in which is why I replaced the IAC. It seems to be better now, but not perfect. Was not able to find any apparent vacuum leaks by spraying carb cleaner on the vacuum lines.
Any ideas?
Any ideas?
