OP
And a selectable doesn't because of the knuckles??Yup, an autolocker works up front because of the knuckles.
I'm lost...
The auto lockers will ratchet as you turn due to the inner axles turning at a slightly different speed when the wheels are turned. There is a pin and ramp in the locker that pushes it apart allowing the ratchet. This is part of the design and allows a slightly easier turning. A selectable doesn't ratchet and therefor, turning while locked can be an exercise in bind analysis... Some people will complain that the auto ratchets even when not in 4wd while turning in a parking lot. Mine does occasionally in my JK, doesn't bother me at all.Trying to follow along with this because I'm in the middle of deciding what carrier to put in the HP30 I'm going to build for my rig.
And I get the problem of trying to steer a locked axle.
But don't the Rubicons have a "locked" front axle? I haven't heard of all the Rubi owners complain about their locker, or is there something different about the Rubi locker over aftermarket.
The HP doesn’t have the issues of an LP with a full case locker. Go with whatever your favorite flavor is.Trying to follow along with this because I'm in the middle of deciding what carrier to put in the HP30 I'm going to build for my rig.
Put the orange-flavored pre-workout down man, it's backing you up and the shit is getting deep. While you're at it, you can step away from the "gO rEaD hOw It WoRkS" nonsense...
go read how a differential works. Then come back and tell us how a NON-steering axle is going to turn with a locked diff or a spool.
Well arn’t you just a judgmental prick.Put the orange-flavored pre-workout down man, it's backing you up and the shit is getting deep. While you're at it, you can step away from the "gO rEaD hOw It WoRkS" nonsense...
At this point I'm not sure if you're being obtuse or if you're just a tad retarded (profile says WV, so I'm going to guess a little of both). Brian asked why a Detroit was better in front vs a selectable, to which you eloquently replied "Because you can steer" (leave the one liners to Blaine, you're bad at it). Then you start ranting about the non-steer axles, then suddenly a selectable turns into a locked diff or spool??...
I know the point you're trying to make - and the sad thing is that I agree with you (I've been a fan of the "Currie Setup" for some time). I was simply trying to add to the discussion or at the least, have you clarify your poor explanation. Myself, I personally hate Detroits in the rear on a street rig - especially in snowy/icy conditions - and will almost always disagree with the notion of "just get used to how it drives".
This isn't news, particularly when some hee-haw comes in with guns a blazin'.Well arn’t you just a judgmental prick.
I get that reading and writing can be challenging on a forum - it's easy for our brains to get ahead of our fingers and eyes. We've all done it, so I'll try this just one more time...Lock the shafts together anyway you like. It’s the dam same. L and R turn at the same speed. The advantage to the front IS the steering.
All of the full case units I know of except the ARB are capable of coming apart in a LP 30. Due to the problems of LP design and housing flex.
My wife drives my jeep with a Detroit. Never had a problem with it. She doesn't even know its in there.There ya go.....
It’s the worst locker you could pick for a REAR AXLE application.
Sure it’s cheap, strong and easy. But the negatives outweigh the positives by a large margin.
On the street, even the “new” soft locker has quirks that need to be adapted to so it’s not like driving your truck like it was before the install. Learning to drive around the “features” does not make it invisible.
We’ve all seen the warnings about driving in snow and ice with auto lockers. It’s true, a locked rear axle will not turn, and will cause the front axle to have less steering authority, increasing understeer.
This same tendency to push the front of the truck around hampers off road performance by increasing turning radius.
A selectable should be the only choice for a rear axle.
This allows the NON-steering axle to steer by allowing the wheels to turn at different speed and different radi.
Discuss
I completely agree. I went with ARB’s specifically to support my extensive mall crawlin’. I’ve not been disappointed.Either way stating the detroit is the worst locker ever is a bit ridiculous. Of course its gonna suck when your in the mall parking lot. Buy what you want and wheel your rig.
I have a Detroit in the rear and love it - it just works. My experience with it is that as long as it is not under load, it's not locked. In your example of descending I'm not sure why it would affect the ability to steer since you're normally braking or in lo gear, you're not accelerating. I've done a lot of switchbacks and tight turning and I don't notice anything objectionable, maybe I drive it different than you do???Regarding Detroits: Ask a Detroit user how his auto lockers feel descending Blackbear. The Irony is, traction is not the issue. Turning radius, braking and backing are the issues. The light, pebbly, surface descending steep, 20 foot radius turns when it's dry is akin to snow; in rain, well..... Under steer is more thrill than one should seek on that trail. I know. My first descent was in an FJ 50, no synch 3sp, no power brakes, marginal clutch and pouring rain; fortunately, no auto lockers. I was puckered and pounding.View attachment 238070
Shit happens here.
If that was the case, wouldn’t the same be true about any full case locker?The TJ's front Dana 30/Dana 44 axles are not good axles to install a Detroit Locker into. They flex a bit too much for the Detroit Locker. In other stronger front axles a Detroit Locker would be a great choice in the right conditions.
Because reverse loading of the axle locks the deteoitI have a Detroit in the rear and love it - it just works. My experience with it is that as long as it is not under load, it's not locked. In your example of descending I'm not sure why it would affect the ability to steer since you're normally braking or in lo gear, you're not accelerating. I've done a lot of switchbacks and tight turning and I don't notice anything objectionable, maybe I drive it different than you do???
No, the ARB and Elocker have a case design that limits the failure potential seen with Detroit's and OXIf that was the case, wouldn’t the same be true about any full case locker?
Learn something new everyday! ThanksNo, the ARB and Elocker have a case design that limits the failure potential seen with Detroit's and OX
