OK. Another question that will be very easy for most of you. However, since I'm a complete electrical noob, here goes. I just got an ARB Compressor that will be used for tire inflation only. I've got it mounted and I'm now down to the electrical connection. There is one section in the directions that says to hook the positive and negative cables directly to the positive and negative terminals of the battery. Then, there's another section that says to connect it to a fuse that is not a constant on circuit. Which one is correct? I've got a 2004 Rubicon.
Sent from my iPad using Tapatalk
