so I was removing the slave cylinder from the jeep when I realized that the pin that was at the end of the slave cylinder that activates the clutch FELL INTO THE TRANSMISSION!! So at the very least i'm agitated because now I have no idea how to get this stupid pin out without dropping the whole trans.
I bought a flexible magnetic pickup to use through the sc hole but I couldn't get it bc it faces the opposite direction from the lowest point in the trans. so basically my question is can I drain this and remove the pin from there?
I also saw on another thread that a guy who had a similar issue so he removed the starter and got it from there.
last thing, I added a picture i took with my phone that shows the view from the slave cylinder hole. I can't seem to figure out what i'm looking at/if it looks right. I'm pretty sure that the thing in the front is the clutch fork but idk what that worn plate is behind it/if that's a bad thing.
