Sorry got the wrong transmission number. I have a 6 speed. I don't consider 65 highway speeds. I stay in 5th now around town highways until we get to 70mph.
There's no reason to get out of 5th if the rpms are the same. All your doing with a regear is shifting permanently by using a higher transmission gear and lower differential gear. If your 3.07 regear by all means. But going into the .83 overdrive and regearing versus staying in the 1 5th and not regearing can give very similar results overall.
If 5 th gear transmission ratio x differential ratio is the same as 6th gear ratio x differential ratio between two different setups the engine does not know the difference.
If I put 4.88 or 5.13 gears I'd likely never use 1st gear and I'd be topped out in 6th. I'd rather leave the room on the top end and shift down. Then for off roading use my transfer case design to regain the overall powertrain low gear ratio.
If I owned an automatic and daily drove it on the 405 in LA, I'd regear the rear to crawl in traffic at idle.
We were averaging 88mph on our trip last week. So if you guys plan on driving slow through Nebraska on the way to MOAB, do us a favor and take highway 30.
The key to take away though is its not just a gear. It's a system. The system should be looked at as a whole. Each change affects another, and you can change things in different places to get similar results. I rebuilt grim jeepers calculations in a spreadsheet and copied out my specific transmission information. Then looked at my typical driving speeds and shift points. I determined it's a better investment to buy a new transfer case for off reading and use my shifter to compensate for slighter bigger tires.
That gives me the best street and on interstate performance while letting the transfer case handle off road performance.
The affect will be very similar overall performance to 5.13 regearing off road if I left in the 231 but not what I needed on road.
