I am planning to install my Savvy control arms this weekend. I noticed the hardware is not the Currie set with a zerk fitting on the bolt head bolt to grease the internal mounting surface. This bolt interface seems like a mounting surface, not a wear or rotating surface. The Johnny Joint center should not move relative to the vehicle frame, and the outer shell rotates with the arm and suspension control arm. The shell has its own grease port.
Should I grease the bolts going in? Or use anti-seize? Leave dry?
How long is the lubricant good to accomplish its mission?
Should I spend the $250 (about $15/each) and purchase the Currie units? BTW, does not seem cost effective.
The Savvy bolts have a higher torque value (66lb and 146lb) than the OEM bolts. Should I use the suggested bolt torque or the OEM specific torque?
Cheers
Steve
Cheers
Steve
