I've got a 2001 TJ with the 2.5 and ax5. Both are in great condition, and like everyone else, I love them, just not the power...
DISCLAIMER:
I've lurked and read up on a lot of the write ups, the general consensus is that the ax5 is terrible for anything more powerful than a lawnmower, and that's okay, it's what it was designed for. What I did find out is that if you put a small block into your jeep with an ax5, you're going to blow it up, as well as your axles. I have seen that it is generally accepted that the ax15 is not going to last paired to a sbc.
I have an older 327 small block, and a jeep with a 2.5/ax-5. I'm a very cheap person, and I want this swap. Bad.
My plan is to use the Novak kit and mount up the 327 with an adapter to the ax5 and pray, as this is the easiest method.
I know it won't last long, but I am hoping if it just sees pavement it may last long enough for me to find an ax15 for a good price.
Question is, once I've got a V8 in there... what should I expect when swapping the adapted ax5 to ax15.. Any specialty parts besides another bellhousing kit? Will the transfercase bolt up? I plan to use the same transfer case till things break and it is necessary to swap.
Okay.. now let's chat. I have a lot of projects to accomplish to make a 327 work. I foresee the following:
1: Need to swap from ax-5 to ax-15 at a minimum once the engine is in.
2: Need to upgrade Dana 35 shafts or swap Dana 30/35 to F8.8 or Dana 44.
3: Need to slap in a new radiator.
3.5: Profit?
EDIT : Changed title to be more accurate.
This will be my first venture into engine swapping jeeps, I am used to motorcycles, so any advice is appreciated...
DISCLAIMER:
3.5: Profit?
