Am I missing anything for lift install?
defenderu
Chicago
I have seen some threads but nothing specific on Currie Rock jock lift. I have an 03 Rubicon
I ordered-
1. Currie Rock Jock Lift CE9801HS
2. Fox 2.0 shocks
3. MT 33x12.50 Wheels and Tires
4. Adams Front and Rear Drive shafts
5. Revolution Axle Shafts (had a leak so might as well do these)
6. Impact wrench, breaker bar, TONS OF SPRAY for bolts, jack, jack stands, socket set, lock tight and anti lock spray.
Anything else I will need or be halfway done and say crap I have to order this.
Reactions: Kooper
A quality drift tool is always a nice tool to have while working in suspension for holes that don't want to line up.
Yes, similar to this would be a ratchet strap or two.
Whenever I do substantial work I like to run all the screws and nuts through a thread restore kit as preventative maintenance. I have an old Craftsman set but this one appears to be the same thing. Mine only goes up to 1/2" and M12 so on the larger screws I just use a wire brush.
Besides the right tools, as nice to have's maybe a creeper and a Tub O' Towels for cleaning areas that will be easier to access once you've removed some of those components.
