That's exactly what's going on. Your evaporator core (radiator looking thing inside your HVAC case) is freezing solid like an ice block. When that happens, no air can get through it (hence you hear the blower running but no air coming out). When you stop for lunch or leave it over night, the block of ice thaws and all that water drains out of your HVAC case drain tube (hence a big puddle under the Jeep). This problem is not specific to your TJ or Jeeps or any other cars out in the market. You typically see this problem happen when humidity is high and temperature is in the low to mid 70's. The humidity build up on evaporator core and can't drain out fast enough so it get's trapped between the evaporator fins which will eventually freeze and block the air flow. The culprit is the design of your HVAC case where your evaporator core is most likely sitting in the case at almost vertical position. It's hard for any condensation to drain out in that position. It's most likely designed that way because the'res only limited space under your dash panel and designing it say... 45° would require a lot of room. So there you have it.
BTW, this is one of the reason why your Jeep or other cars smells like something is dead inside when you first turn on the A/C. What you're smelling is mold build up on the evaporator core.
