Is this broken Smittybilt winch fixable?
kiwi
Seattle
Broke my Smittybilt XRC 9500 winch, is there any way this is fixable? It’s only one of the 4 mounts that broke. Thanks.
If smittybilt can’t help, and it’s an aluminum alloy, a good weldor could weld it up. Provided it can be dissembled to the point where it has no seals or plastic parts left in the casting. If anything is left in the case, it could be damaged by the extreme heat of the welding process.
Reactions: kiwi and Zorba
I saved a copy of it which will come in handy the next time someone asks about buying a Smittybilt or other cheap/similar quality Chinese winch.
I wish i could afford a warn winch, but there’s not many other choices when the budgets low.
Reactions: hosejockey61
Before you bolt another winch back on the mounting plate you need to diagnose why that failed. Did you have a bolt come loose or is the mounting plate distorted in some way? Were you pulling off angle for an extended period and the wire rope balled up on the drum flange and pushed the winch away from the mount? From what I can see in that pic the drum support did not have a fracture so it was not a bad casting.
Reactions: Gollywomper
Imagine a winch flying through the air, Off the front of your rig, smashing someone square in the face(probably your wheelin buddy), Good chance they would be seriously injured(if they are the tuffest mofo ever to life........) SHITTYBUILT
Interesting. I've had mine since 2014 and its pulled me out of thick texas mud and winched a disabled cj5 through some gnarly rocks in the sierras, along with little here and there use through out the years. No issues yet.
