If you have the schematics you will have to splice into a couple wires on the brake switch and a couple on the new clockspring,your gettingbcloseYes it’s already wired in
Do you have a cruise light?Looking again I have this plug not wired up yet. You guys said this went to the clock spring correct? What wires?
There’s one in my dash however it never turned onDo you have a cruise light?
There’s one in my dash however it never turned On
Yes so I ran wire from the connector to the wires that matched in the clock spring ( see picture) and that’s when I began to have the issue I sent in the video above.The two wires on the black plug go to the two wires on the natural plug in the first picture. The natural colored plug is for the clock spring. The third wire RD/YL pointing straight up is the horn wire. With out these connected the cruise will not work.
Yeah I just triple checked the wires I ran the brown with yellow to the brown with yellow and the red with yellow to the red with yellowWhat was the actual part number of the two switches you installed including the suffix letters? If you have clear picture of the back of them that would be even better. Double check you went to the right two wire on the clockspring as well the the BR/YL one would be hard to get wrong but make sure the RD/YL is wired to the next wire and not the horn/
If you are idle you should be able to push the button and the light should come onI assume the red with yellow wire goes to the red with yellow on the clock spring but I don’t know where the second would go.
The brown yellow wire goes to a splice S107 from there it goes to the battery temp sensor and to the A4 pin on C2 plug of the PCM. you already had a battery sensor and the wiring on yours would have gone to the A4 pin not sure how you wired it but you need to retain the connection to the A4 pin as well as going to the clock spring. The numbers on the back of the switches are important there is one set for 1997 56007530AB and 56007531AB, another set for 1998 56007530AC and 56007531AC, another set for 1999-2002 56007530AD and 56007531AD and a fourth set for 2003-2006 56042310AC and 56042311AC all of which use different resistors . The can bus system in the PCM requires precise changes in the 5 volt system to do what you want it to, resistance reading out of spec can cause all kinds of weird things or nothing at all to happen. This is a simplified wiring schematic double check all your wiring you can test them with a ohm meter, from say C4 directly to #1 pin on the servo plug or C11 directly to the #2 pin on the clock spring. Just make a jumper out of some long wire to get one side to reach the farthest pins, alligator clips help or a second set of handshetting the light is a good sign,but he’s right,it only took a couple minutes for me and my wife with my audible continuity setting on my meter to check all the wires I did, all checked out,my problem was the speedometer gear was not yet changed for my bigger tires
Right now the brown and yellow wire I have ran only to the clock spring same with the red and yellow wire. The battery temp I have the one on this harness plugged in just sitting in my engine bay.The brown yellow wire goes to a splice S107 from there it goes to the battery temp sensor and to the A4 pin on C2 plug of the PCM. you already had a battery sensor and the wiring on yours would have gone to the A4 pin not sure how you wired it but you need to retain the connection to the A4 pin as well as going to the clock spring. The numbers on the back of the switches are important there is one set for 1997 56007530AB and 56007531AB, another set for 1998 56007530AC and 56007531AC, another set for 1999-2002 56007530AD and 56007531AD and a fourth set for 2003-2006 56042310AC and 56042311AC all of which use different resistors . The can bus system in the PCM requires precise changes in the 5 volt system to do what you want it to, resistance reading out of spec can cause all kinds of weird things or nothing at all to happen. This is a simplified wiring schematic double check all your wiring you can test them with a ohm meter, from say C4 directly to #1 pin on the servo plug or C11 directly to the #2 pin on the clock spring. Just make a jumper out of some long wire to get one side to reach the farthest pins, alligator clips help or a second set of hands.
I actully don’t have a light bulp in my cruise control slot after I pulled it out and lookedIf you are idle you should be able to push the button and the light should come on
I would get it in there so you can tell if that part worksI actully don’t have a light bulp in my cruise control slot after I pulled it out and looked
