Trying to find a source for transfer case shifter rubber grommets
Nomader
Chatsworth GA.
2004 4.0 5 speed
Forgive me if it's been asked couldn't find answer. Just did complete clutch and trying to find a source for rubber grommets in transfer case linkage. Also is it normal for clutch to be very easy to apply after replacing? I replaced everything, clutch kit, flywheel and master/slave cylinder.
Thanks all.
I can not offer a source for the grommets I'm sorry to say, but I can offer some advice: Ditch the linkage and go with a cable. I swapped mine out after a linkage failure and it is a huge improvement. I went with the NOVAK brand because it was available, most will recommend Savvy if you can get in touch with them.
Reactions: Zorba
Regarding the clutch pedal feel, yes, it is normal for it to feel much lighter. Same thing happened with mine.
