Wait a second. What exactly are those for? I don't have anything quick disconnect that I know of and I don't mess with the frame when folding the top back it just folds back. Am I doing something wrong? LolDo you have the rear brackets that hold the tailgate bar to the tub? https://www.amazon.com/dp/B076Y139ZP/?tag=wranglerorg-20 (you’ll need a left and right)
Another thing to consider are the Bestop quick disconnects for the knuckles. Tool-free install and removal of the top. https://www.bestop.com/jeep/2017/wrangler/bow-knuckles/door/2/
They just make installing the bows to or removing the bows from the brackets a tool-free job. They work the same as the stock hardware when folding the top up or down.Wait a second. What exactly are those for? I don't have anything quick disconnect that I know of and I don't mess with the frame when folding the top back it just folds back. Am I doing something wrong? Lol
Stupid question.... So is that just for taking the entire top with frame on or off the jeep?They just make installing the bows to or removing the bows from the brackets a tool-free job. They work the same as the stock hardware when folding the top up or down.
Exactly, just install and removal.Stupid question.... So is that just for taking the entire top with frame on or off the jeep?
My OEM soft top has the Sunrider function (Sunroof bit) They were a factory option on mid to late 06 and onwards.Thats not an OEM frame, that's a Bestop Supertop frame, surely? My OEM frame doesn’t have the sunroof bit.
I dont think it is? I have the OEM factory sunrider and I think the NX has a slightly different folding mechanism on top of the door surrounds. OEM "without" the sunrider would be a different header as well, My OEM has 2 sockets moulded to the header one each side where the flip bows are fitted to.I was asking if the Supertop NX is the same header as the oem. I think that is the case, but the Supertop (no NX) is different.
I like thatHow did no one just link this:
http://site.justforjeeps.com/guide/82207728.pdf
You we need a Tailgate hatch seal and the brackets to install it. These are used to secure the back window to the frame in its closed position.I have a 2004 Wrangler that apparently was not outfitted for a soft top. I acquired an OEM (never out of the box) top with all the windows, door opening frames, etc...I have ordered a set of the Pivot Brackets for the bows. But do I need anything else (hardware-wise) for the header, tailgate, or whatever?
As always, thanks for all the help you provide.
Yup. The top came with that and all parts except for the quick releases, and the roll bar attachment brackets. ThanksYou we need a Tailgate hatch seal and the brackets to install it. These are used to secure the back window to the frame in its closed position. View attachment 247626
Dumb question. On my sons 99, we took the hard top off and put a soft top. It's a rampage black diamond. It has the full front doors. The kit we got was the full kit with hardware, however, it does not have surrounds. Are these needed when using the full door? I am inclined to get some, as I think it would look cleaner.
Yes, you need the door surrounds. The soft top attaches to surround in a groove to pull soft top taught. Also, the door seals against the surround to keep the water out. The surround does add support for the doors window frame too, otherwise the door frame around glass would crack at top of door panel from moving without support.Dumb question. On my sons 99, we took the hard top off and put a soft top. It's a rampage black diamond. It has the full front doors. The kit we got was the full kit with hardware, however, it does not have surrounds. Are these needed when using the full door? I am inclined to get some, as I think it would look cleaner.
We are new to the Jeep world and still learning.
Those aren't standard door surrounds. Just fyi.View attachment 254839
This is how it looks. There is a support at the top now with the current hardware.
That's an aftermarket soft top mount, it's way different from the much easier to use factory soft top mount.View attachment 254839
