I’ve got a pretty obvious rake after doing the 2.5” OME lift. I need to add some spacers up front to level it out, but how do i figure out what size spacers i need to make it level? Thanks in advance!
Oops, just fixed the titleI always add 1" spacers or longer springs up front. Measuring from the top of the tire to the bottom of the flare will give you an idea of what you what you need. They still sit slightly higher in the rear.
p.s. I NEVER ride people in the back seats. Your title says wheel spacers.
Zone 4.25" lift/1" spacers up front and 35s. I have the same setup on my current Rubicon.Oops, just fixed the title
What size tires/lift are you running in the last pic?
Nice, looks great. And what rocker guards?Zone 4.25" lift/1" spacers up front and 35s.
Haha, those are actually the ones i'm looking to get. How'd you like them? Are they worth the price or should i get the savvy rocker guards instead?
Should it come up higher at the back with an empty tank?Oh, is the tank full of gas in the picture?
That just means your springs are good.Should it come up higher at the back with an empty tank?
Mine doesnt seem to change loaded or unloaded.
Cheers.
They worked great for the price. Savvy would be much better quality though. They should be for 3 times the price.Haha, those are actually the ones i'm looking to get. How'd you like them? Are they worth the price or should i get the savvy rocker guards instead?
I dont think there is any ass end up? if you look at Boogiemans 1" extra in the front post#8 there is about the same difference between front and rear as your own , I think its the fender flare shape difference between front and back that is throwing you off and making the rear look higher than the front. If you snip the two pics and look at them side by side the geometry is very similar in my way of viewing?I’ve got a pretty obvious rake after doing the 2.5” OME lift. I need to add some spacers up front to level it out, but how do i figure out what size spacers i need to make it level? Thanks in advance!
Reviving my own old post but just wondering, does running with 1" spacers up front effect off-roading? Should i be any more cautious or anything?I always add 1" spacers or longer springs up front. Measuring from the top of the tire to the bottom of the flare will give you an idea of what you what you need. They still sit slightly higher in the rear.
I’m not really sure what you mean by that. Other than changing shock bias, and maybe having to change bump stops, what could happen off-road that wouldn’t happen onroad?Reviving my own old post but just wondering, does running with 1" spacers up front effect off-roading? Should i be any more cautious or anything?
