Hoping I can get some level of confirmation I'm on the right track with my post lift vibration. I think I've read just about everything, but something's are a little changing for me.
I put on:
2" EMU Suspension Lift
EMU Transfer Case Drop Kit
33" tires - Baja MTZP3 Radials
Vibration right after install. It's starts at about 40mph, and gets stronger thru 50, and then pretty much goes away by 55.
I've aligned the front end and had the tires rebalanced at a shop I confirmed can deal with the larger tires.
Vibration still there.
SO, .... I just removed the front drive shaft and the vibration is worse!!!! I now notice it around 30mph and it's still there at 65.
Makes me think it must be the rear Driveshaft. I'm guessing with the front installed it might have acted like a damper???
Am I on the right path? Replacing rear U-Joints next?
Thanks,
Bob
I put on:
Thanks,
Bob
