I have a new vibration from my front axle/driveshaft that driving me nuts. I installed a 3" lift kit in my LJ about 5 years ago. Everything was great until I regeared the axles. I resolved the problem with a SYE, Adams double cardan rear driveshaft, and some adjustable upper rear control arms. Pinion and driveshaft angles were within a degree of each other for both the front and rear axles.
For the past several years, I was vibration free. This past Spring, I picked up a vibration that was very noticeable around 60 MPH. I was pretty certain the vibration was from the front, but I ignored it until my front pinion seal started to leak. Eventually, I removed the front driveshaft and replaced the pinion seal. I noticed the the factory balance weight on the front drive shaft had fallen off (looks like the welds rusted through). Without the front driveshaft, there was no vibration up 80+ MPH.
I rebuilt the joints in the front driveshaft and had a local shop balance my driveshaft. When I installed the driveshaft, the vibration returned and was more intense. It still occurred at the same speed as before. I installed an Adams front driveshaft and there was no difference. I remeasured my pinion/driveshaft angles and they may differ by 2 degrees. If you were looking at the front axle from the driver's side, the front axle would have to rotate counter clockwise to match the pinion angle.
Other Things I’ve done to try and resolve the problem;
I’m not sure what to do next, and am looking for some suggestions.
- I removed the rear driveshaft and drove around in 4WD with the front driveshaft. The vibration was still there.
- I removed the front driveshaft, again, and the vibration was gone.
- I checked both front and rear pinions for play while not connected to a driveshaft. Neither had any up/down or in/out play. Both had left/right rotation, which I assumed was backlash. The rear pinion was maybe 1/8” left/right, while the front pinion was a good ¼” left/right rotation.
- I didn’t notice any up/down or in/out play in the transfer case yokes.
- The transfer case yokes spins freely.
- I removed the front differential cover and did not see anything obviously wrong. I could see shiny very fine metal particles, but no large pieces, in the oil.
