i have 5.25 kickers all around and a kicker sub in the factory location.
i plan to add two jl 10's in a subthump box and a jl 5 channel amp for interiors and subs.
feels like the factory speakers in the dash arent really doing anything?
I’ve been thinking about doing that. I thought about moving to 6.5 in the sound bar but I’ve heard having same size speakers is better for sound stage.
Got it, what do you think of the subthump box: https://subthump.com/Jeep-Wrangler-...-clone.html?osCsid=tmjpogf3q30mhkeg7gv80g0in7
Can’t decide if I should ditch the factory sub when I add the box?
Any photos?Assuming you have available space in the rear, and are cool with that box there. For $200 that is a good buy.
I will say though, map out your system prior to buying anything. You want to get the right amp to match with the speakers.
Also, I use my factory sub, but I also have a dual 10" box in the rear...but if I need the rear space, that sub box can be easily removed.
This is what I have in the back, cost was $300 shipped and included the speakers. There is a quick disconnect so I can easily remove, when needed.
https://www.crutchfield.com/p_975PP10ED/MATCH-PP10E-D-Compact-Sub.html
Any photos?
Any photos?
This Ebay post references the PP 62DSP and the seller has a PP 8EQ.
You could offer a bundle for like $500 all-in...and will have a great amp with subwoofer with quick disconnect. This amp is better suited for speakers that draw 2 ohms, so BLAM would be a great option.
https://www.ebay.com/itm/Audiotec-F...d=link&campid=5337789113&toolid=20001&mkevt=1
https://www.audiotec-fischer.de/en/match/subwoofers/pp-8e-q
thanks, ill take a look!
