Currie then the JKS. As for RE, my track bar has about a decade on it and no issue.So Currie and JKS are better options?
Sent from my SAMSUNG-SM-G891A using Tapatalk
Does this steering damper have everything I need? @Jerry Bransford mentioned the stock tapered end and needing new hardware. I know a steering damper is a basic dual valve so nothing fancy needed. This ones pretty cheap and matches some other RE stuff I have on the Jeep.
https://www.amazon.com/gp/product/B00E0REY24/?tag=wranglerorg-20
Yes, that will work. This is another popular choice as well:
https://www.amazon.com/dp/B000C53XRK/?tag=wranglerorg-20
Oh great, I bought the one you suggested and now @Ahoragi says it's gonna rust. Arghhh. I'll paint it I guess. Just another thing to do. Thanks though. I'm sure it will get the job done. At $24 it's not much!Yes, that will work. This is another popular choice as well:
That would be hilarious, if it wasn't so painful (and true).Our vehicles biodegrade here in PA thanks to road salt.
Looking for some recommendations for a good replacement Stabilizer and possibly a front track bar
Had death wobble for 4 years changed everything called 4wd. talk to them bought thre Fox 2.0 steering stablizer said it was for 37in. tires said it might pull a little i didnt care if it takes away the wobble to my surprise GONE.. cant beleave it 4 years and its totally gone so happy.
That's why I'm going with the balancing beads. To solve DW. I thought I solved it with a new MC trackbar. It did help. But got it today, first time since May. Trackbar is still good at the axle. Beads first. I expect this will solve it. If it does I'll add the new stabilizer. Stabilizer doesn't solve DW, it only hides it for awhile. Wish I were wrong for everyone's sake, but I'm not. My alignment is perfectDo you know you did not solve the wobble issue?
It is probably your tires.
