My son is looking for a TJ. I know the latter ones were a V6 and I have had no experience with them. Was the V6 better and more desirable than the straight 6? Or should you stay away from the V6? Ant advise or suggestions would be appreciated.
While the 3.6L V6 Pentastar creates more power and gets better MPG; the amount of electronics required to accomplish this can be much more expensive to repair than the 4.0L.The JKs come with V6s. The 3.8 V6 offered in the 2007-2011 JKs is NOT a better engine than the 4.0 in any way if you ask me. It’s also severely underpowered.
The 2012-2018 JKs came with the 3.6 V6 Pentastar which is a fantastic engine, worlds better than the 4.0 in terms of power.
The 4.0 is definitely a reliable engine, which is about all it has going for it. I have a love / hate relationship with the 4.0. My 3.6 Pentastar was a fantastic engine to drive on the road, but as you shed light on, it’s not the best choice if you’re a DIY mechanic as the electronics are much more abundant.While the 3.6L V6 Pentastar creates more power and gets better MPG; the amount of electronics required to accomplish this is can be much more expensive to repair than the 4.0L.
The 2012-2014 engines were prone to numerous head problems so much so that the PN last two letters went from AA to AE with in 3 years due to redesigns trying to correct the valve issues. As far as I know that problem has been resolved, but not after a lot money was invested.
I may be biased, but I prefer the durability and simplicity of the CLASSIC TJ over the JKs....
X2 Plus if you start down the rabbithole of replacing the oil pressure sensor with the same half ass factory parts over and over,it’s not the best choice if you’re a DIY mechanic as the electronics are much more abundant.
Very true indeed. The JKs have lots of little issues like this that are very well documented.X2 Plus if you start down the rabbithole of replacing the oil pressure sensor with the same half ass factory parts over and over,
you find yourself wondering if keeping it past warranty is sustainable.
I’m absolutely biased. Even with the non-crossflow, 2 valve, OHV, heavy iron block and head, I like the 4.0 better than a V6. A straight six is smooth, sounds nice, is easy to work on and makes most of its torque over most of its RPM. Every straight six I’ve owned (Ford 4.9, Cummins 6.7, BMW 3.0 and the Jeep 4.0) had those characteristics. There are more than a few nice performing V6s out there, but they just aren’t cool. Was anybody excited about the V6 Plymouth Prowler? Happy to see Ford put a V6 in the Raptor or GT? Big power in both of those but, meh...... I may be biased...
350- 450 K Sure, but I believe at 600 K any 242 would be getting VERY long in the tooth , your cam would look like a pipe and yourIt's nice knowing at least that with the 4.0 as long as you take care of it it should make it pretty easily to 600k miles or so without a rebuild.
Possibly, but that guy here on the forum had 600k on his TJ when he sold it, never rebuilt the engine either350- 450 K Sure, but I believe at 600 K any 242 would be getting VERY long in the tooth , your cam would look like a pipe and your
timing chain would have enough slop to slap the hood.![]()
That is Great ! I hope I can get that out of mine too ! Most of the non roller engines can't get that kind mileage.Possibly, but that guy here on the forum had 600k on his TJ when he sold it, never rebuilt the engine either![]()
Yes sir.
Jeep rated the '97 4.0L at 222ft/lb (at the crank). Mine recently dynoed 169ft/lb (at the rear wheels) but the curve was almost flat with near full torque from 2100RPM to redline. I put the dyno sheet in my build thread (https://wranglertjforum.com/threads...en-tj-moderate-build.51602/page-3#post-928126)I haven't seen any mentions of the torque that the TJ's Inline6 makes. Or the RPM is does it at...
The 4.0 is great. It's an almost bullet proof package that has grunt down low where we like it.
